Browse Forums Renovation + Home Improvement Re: Bouncy floor in 1990's home 3Aug 25, 2022 7:03 pm oldchippy Floor joist arrangement seems ok provided they are of continuous span (single span 1700) Bearer at 2100c max span should be 1700 for cont. or even as low as 1500 for single. Maybe that's where your bounce is. Seems a bit of space under your floor, why don't get under there and have someone walk around inside. If it the bearer bending, just gun nail another piece of timber from stump to stump in the areas of concern. Thanks - there's space at this end, but less at the other end . If the design is OK, then what you've suggested is the next step I guess. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17138 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17945 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 17368 |
