Browse Forums Renovation + Home Improvement 1 May 20, 2022 10:15 am Hello forum, I have ridiculous external cupboard at the back of my house which backs onto my laundry. I'm looking to close in the external cupboard and use the space for internal cupboards in the laundry. I'm looking for some advice on which way to go re the material to use (brick or stud wall), and what the waterproofing requirements might be. I live in Brisbane and the cupboard does get flooded from time to time so the solution needs to be water resistant. The flooring in the cupboard is part of the house slab. I'm happy to DIY a stud wall, but would get a brickie if that's the path I take. The dimensions are 2290 wide X 2250 high. Thanks, Hugh Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Close in external cupboard - Brick or stud & blue board 2May 20, 2022 5:51 pm hughbert Hello forum, I have ridiculous external cupboard at the back of my house which backs onto my laundry. I'm looking to close in the external cupboard and use the space for internal cupboards in the laundry. I'm looking for some advice on which way to go re the material to use (brick or stud wall), and what the waterproofing requirements might be. I live in Brisbane and the cupboard does get flooded from time to time so the solution needs to be water resistant. The flooring in the cupboard is part of the house slab. I'm happy to DIY a stud wall, but would get a brickie if that's the path I take. The dimensions are 2290 wide X 2250 high. Thanks, Hugh Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ if you mean that the backyard is occasionally flooded and potentially wet against the new wall i would first aim to restrict all water from anywhere near the house (eg a concrete footpath a step lower than the floor of the house and sloping away from the walls) and build a new stud wall with painted cement sheet wall cladding inside and out and unless you're lucky enough to be free of mould consider plastic coated steel mesh for shelving (see flatpac wardrobe fixtures) and avoid adding doors to the new cabinet and/or allow for generous ventilation Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3625 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 3076 |
