Browse Forums Renovation + Home Improvement 1 Mar 21, 2022 10:05 pm Hi Homeone crew, I'm really keen on your collective feedback on extension plans we are working through at the moment, and any fine tuning you might recommend. We are at the front of a what i'd call a very large block (1370m2) backing onto quite a noisy road. Original house was built in 1971. We were keen to go KDR but our budget meant we needed to work with the high volume builders, and it turns out they are not fans of the 2+metre cross fall we have. Here are the plans so far (red lines are existing walls being deleted) Block view, including proposed extension and garage. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Upper Floor Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Downstairs originally just a single garage but previous owners excavated quite a bit and put a bunch of steel beams in. Ceiling height isn't great. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: North East Facing Canberra Home Extension - Plan Feedbac 2Mar 23, 2022 2:54 pm shizzlemkizzle Hi Homeone crew, I'm really keen on your collective feedback on extension plans we are working through at the moment, and any fine tuning you might recommend. We are at the front of a what i'd call a very large block (1370m2) backing onto quite a noisy road. Original house was built in 1971. We were keen to go KDR but our budget meant we needed to work with the high volume builders, and it turns out they are not fans of the 2+metre cross fall we have. Here are the plans so far (red lines are existing walls being deleted) Block view, including proposed extension and garage. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Upper Floor Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Downstairs originally just a single garage but previous owners excavated quite a bit and put a bunch of steel beams in. Ceiling height isn't great. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ i would prefer the stairs to be central so that there is more useable floor space upstairs with an optional bathroom an dkitchen nook could make a comfortable self contained space Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ the new master suite looks ok but please explain the the sliding doors with access to external stairs and is there a size limit to the master suite as i would sacrifice some of the master bedroom space for a more generous ensuite as the new ens feels cramped Re: North East Facing Canberra Home Extension - Plan Feedbac 3Apr 04, 2022 1:30 pm Hi Oklouise, Thanks so much for the feedback and taking the time to respond. We definitely looked a putting the stairs in a more central location, but you can see the outlines of the underlying steel beams that meant the stairs could only really end up in an awkward position. The alternative is to simply stick with the dangerous spiral staircase we currently have. The kitchen placement actually works pretty well where you have placed it, even with the proposed stair location in the far corner.. Would you say its unusual to have a kitchen facing the street? That is a good question about the external access from that end of the house, its something our home designer added as part of the initial concepts and I didn't question it at the time. Great point on the bedroom ensuite, there isn't any space constraints, and the room is probably slightly oversized to our needs. We are trying to rework the layout a bit to get more hanging space in the WIR as well. Again, thanks so much for the feedback and drawings. . Re: North East Facing Canberra Home Extension - Plan Feedbac 4Apr 07, 2022 4:35 pm shizzlemkizzle Hi Oklouise, Thanks so much for the feedback and taking the time to respond. We definitely looked a putting the stairs in a more central location, but you can see the outlines of the underlying steel beams that meant the stairs could only really end up in an awkward position. The alternative is to simply stick with the dangerous spiral staircase we currently have. The kitchen placement actually works pretty well where you have placed it, even with the proposed stair location in the far corner.. Would you say its unusual to have a kitchen facing the street? That is a good question about the external access from that end of the house, its something our home designer added as part of the initial concepts and I didn't question it at the time. Great point on the bedroom ensuite, there isn't any space constraints, and the room is probably slightly oversized to our needs. We are trying to rework the layout a bit to get more hanging space in the WIR as well. Again, thanks so much for the feedback and drawings. . some more ideas to consider with space for bathroom and kitchenette downstairs makes for a self contained suite, upstairs has smaller sliding glass doors to allow for more kitchen counter and i've added a fridge in eth kitchen and master suite has and an extra 1.7m of storage wall for the wiw and a wider vanity and wall space for towel rails in the ens Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The warning is on the sticker on the door too. Second the aluminium powdercoat 6 19109 Hi, can anyone recommend a custom home builder who can build in north east area? Looking to build a custom 4-br energy-efficient home with a max budget of 750k. If they… 0 23649 May I ask why you chose not to use GJ Gardiner? I'm actually meeting with one of the sales guys tomorrow for an appointment. Definitely not signing anything yet… 3 14035 |
