Browse Forums Renovation + Home Improvement 1 Jan 09, 2022 9:22 pm We will be getting the facades of our house rendered. We have this brick pattern where it petrude maybe 40mm. How would we straighten this out so that when it is rendered, it is all flush? I found a renderers instagram that this can be done, just not sure how. Would they foam the whole facade except this section? [img:1nz23gfa]https://forum.homeone.com.au/u/47615_1641727389.jpg[/img:1nz23gfa] [img:1lauj0le]https://forum.homeone.com.au/u/47615_1641727411.jpg[/img:1lauj0le] Re: How to render my facade and have all bricks flush? 2Jan 09, 2022 10:21 pm It would be better to jackhammer of the small raised section of brick and render it flush. Then texture the whole lot. If you put foam on the facade you will lose the fascia at the roof line. I'll put your picture below so people can see what you mean. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How to render my facade and have all bricks flush? 3Jan 09, 2022 10:23 pm lockmac We will be getting the facades of our house rendered. We have this brick pattern where it petrude maybe 40mm. How would we straighten this out so that when it is rendered, it is all flush? I found a renderers instagram that this can be done, just not sure how. Would they foam the whole facade except this section? [img:1nz23gfa]https://forum.homeone.com.au/u/47615_1641727389.jpg[/img:1nz23gfa] [img:1lauj0le]https://forum.homeone.com.au/u/47615_1641727411.jpg[/img:1lauj0le] Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How to render my facade and have all bricks flush? 4Jan 11, 2022 1:31 pm Thank-you for that. I spoke to my chippie and he suggested to use a angle grinder and then a honing disk. Also mentioned a hammer drill maybe. Is this what you would think would be the easiest way? I think getting a Jack Hammer would be quite difficult. Re: How to render my facade and have all bricks flush? 5Jan 11, 2022 2:19 pm I'd use a saw (angle grinder or quick cut) to put some vertical cuts in the raised section of bricks. Then I'd use a small jackhammer to knock the bricks off. Half the brick will still sit there. Then float that section so it's nice and flush. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16238 Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3673 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 2897 |
