Browse Forums Renovation + Home Improvement 1 Nov 19, 2021 1:58 pm Hello everyone, Newbie here, sorry if this is not the right place to post my query. We are planning to build an extension at the side of our house which is a corner block. This is Boroondara council in Victoria. The requirement for a side setback is 2m. Our proposed single story extension is 1.5m from the boundary, however adjoining the boundary wall (which is just 40cm high) is a 50cm wide garden bed (see pic below). Not sure if this is on title (will have to get a survey done). If I include this garden bed then the setback from the footpath meets the required 2m. Could anyone share their experience/thoughts on whether we can get our plan approved or will Council simply reject it straightaway? Thanks for any advice. . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Extension and side setback 2Nov 19, 2021 6:32 pm most likely garden bed is council land if you go to mapshare https://mapshare.vic.gov.au/MapshareVic/ you can find your property dimensions and then measure them Re: Extension and side setback 3Nov 20, 2021 8:54 am Wow, thanks so much for that aussieta! Really helpful. Are dimensions reasonably accurate? Looks like the garden bed outside the compound wall is on title as per mapshare. Plan to take an appointment and visit the council soon. Regards Kas This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 4060 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 16319 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6628 |
