Browse Forums Renovation + Home Improvement 1 Oct 01, 2021 12:04 pm Re: Double story windows layout help 4Oct 11, 2021 3:37 pm Hello VOV, I agree, I don't like your façade either. The reason is that there is no symmetry between ground floor and first floor, it looks like 2 different houses. Try to carry the window spacing across the levels so that it all lines up. Try to have the same shape of window and even consider the same windows up and down Here's one we did, the customer had chosen different products above the bifold doors and there was no way that they would look symmetrical. We used standard windows and coverplates to create the illusion of a wall of light. Externally as well, it all aligns. If you get stuck, talk to me. . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ . "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double story windows layout help 5Oct 12, 2021 9:36 am ECOECO Hello VOV, I agree, I don't like your façade either. The reason is that there is no symmetry between ground floor and first floor, it looks like 2 different houses. Try to carry the window spacing across the levels so that it all lines up. Try to have the same shape of window and even consider the same windows up and down Here's one we did, the customer had chosen different products above the bifold doors and there was no way that they would look symmetrical. We used standard windows and coverplates to create the illusion of a wall of light. Externally as well, it all aligns. If you get stuck, talk to me. . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ . Thanks Ecoeco We have come up with 4 design ideas. Prefer design ‘A’. What do you think? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Double story windows layout help 6Oct 12, 2021 1:20 pm I'm thinking on these lines. The benefit of the lower one is that you won't need restrictors on the opening windows. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double story windows layout help 7Oct 14, 2021 11:01 am Thanks ecoeco I like your first design. We can not go with the second design though we like the big windows very much as this is the double story extension. I try to keep the original windows to save the cost. Re: Double story windows layout help 8Oct 14, 2021 1:19 pm Yes, I realised too late that the ground floor was existing. Whatever you do will be a compromise, I am sure you will be comfortable either way.... "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double story windows layout help 9Oct 16, 2021 8:43 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Ecoeco, What do you think about the material of the facade we should go with? Render or weatherboard? And what color do you think it will make a nice standout with current brick? I prefer the materials in the picture below. Is render be the best cost efficient? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4653 5 19533 This thread is over 6 months old. I'd say the OP has long since decided on their layout. 5 20057 |
