Browse Forums Renovation + Home Improvement 1 Aug 07, 2021 8:34 pm We are starting to get our base plan together ready to get drawings done in the coming weeks/months. Our existing house has 2400mm ceilings, and we will be extending part of the roofline out (we think) by 1.5-2m, and then a whole new section that will be 2700mm. If you have an external roofline that has this ceiling height difference, can you share how it’s been done, trying to get this right in my head before we decide on final plans Re: Extension 2400 to 2700 ceilings 2Aug 08, 2021 1:36 pm Ashb234 We are starting to get our base plan together ready to get drawings done in the coming weeks/months. Our existing house has 2400mm ceilings, and we will be extending part of the roofline out (we think) by 1.5-2m, and then a whole new section that will be 2700mm. If you have an external roofline that has this ceiling height difference, can you share how it’s been done, trying to get this right in my head before we decide on final plans we need to see your floor plans to better understand the new spaces but easiest way to change ceiling heights is not to attempt to have them match by keeping the dividing walls and inserting a doorway so new and old rooms have separate ceilings and then the height of the new ceiling can be increased by building a taller extension OR by stepping down to a slab on ground 9with or without a link to join the two sections which is much easier for the whole structure if the original floor is on stumps Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 40917 I was quoting framing timber sizes from Australian Standard AS1684.4 Table A13 for 2700mm wall heights Tile Roof, single storey. This Australian Standard doesn't refer to… 8 7614 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8980 |
