Browse Forums Renovation + Home Improvement 1 Jul 12, 2021 9:06 pm Hi All, hoping for some suggestions on what we can do to our house. We renovated out the back and added a large extension (Blueboard) but need to do something with the house with either render or cladding or both. Were thinking of rendering the lot but wanted to get any ideas on what else might work. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4933 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7625 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5267 |
