Browse Forums Renovation + Home Improvement 1 Jul 12, 2021 9:06 pm Hi All, hoping for some suggestions on what we can do to our house. We renovated out the back and added a large extension (Blueboard) but need to do something with the house with either render or cladding or both. Were thinking of rendering the lot but wanted to get any ideas on what else might work. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5466 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 10431 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 6286 |
