Browse Forums Renovation + Home Improvement 1 Jan 02, 2017 4:54 pm Hi, Hopeing someone can point me in the right direction. I'm wanting to replace a sliding door with stacker doors and increase the size of the opening from 1.8 to approx. 3.6m. Its an external wall where the dining opens up to the patio. I want to find out what size beam I will need for the new span. Where do I find the appropriate span tables and how do I read them? What is the process for this situation? Is there a mobile app I can use? I'l post some pic's up if I can work out how to do it... Fyi - My house is a 70's brick veneer low set concrete tile roof. As for the roof structure I cannot say at this point in time as I cannot get access without removing tiles. Appreciate your advice. Re: Help with beam size for new opening 2Jan 07, 2017 3:23 pm You will need to seek out an engineer who will do the comp's for you, which you can attach to your plans you have had drawn up for your proposal when you lodge them for a building permit. Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 13350 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27816 I would like to build our new house with the rear section approx 1 metre out of the ground, I don't particularly like to go bearers and joists so concrete slab all the way… 0 3996 |
