Browse Forums Safer Living 1 Dec 04, 2014 9:50 am Hi All, Current build has a Networkx NX4 (Hills R4) being installed by the builder. Post Handover, I want to add in the ComNav system, as well as remote system or prox card disarm to the alarm. My understanding is that the NX4 does not support ComNav from what I have read, and that the NX8/R8 will only support 1 expansion (so either remote or comnav.) Basically want ComNav for notifications to my phone, which is probably more important to me than the remotes. Would skip remotes if I could install a prox/credit card paywave reader to disarm/arm the alarm easily... So - alarm experts - how much am I looking at for just an R8/R12 panel to upgrade to (if required - if I could add the ComNav to the NX4 I wouldn't upgrade...) Also - where is the best place to get the ComNav from - cheapest I have seen around is about $160. Thanks in advance. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15791 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20417 |
