May 24, 2013 11:55 pmSign In28 members logged in
Building Forum » Building, Renovation & Maintenance » Safer Living
Safety Switches / Surge Protection
New Topic Post Reply  Page 2 of 2
 [ 27 posts ]  Go to page Previous  1, 2
grinder
 Post subject: Re: Safety Switches / Surge Protection
PostPosted: Aug 19, 2009 10:19 pm
I do not guys this seems a clouded issue to my in my last attempts to investigate power surges many years ago I borrowed from our engineers (distribution engineering) some equipment and found the source as an adjacent substation 100ms away.
So just blame your utility for that :lol:
As for storm surge well best protection is to switch off appliances and not use the telephone lines I reckon
westom
PostPosted: Sep 08, 2010 3:39 pm
New Poster
New Poster
Quote:
My board is a three phase. Are there surge diverters from ABB which would fit onto a three phase? At the moment my electrician is suggesting a diverter for each phase but I am sure there are units that cover all three phases?
Every wire inside every cable makes a 'less than 3 meter' connection to earth. If any one wire does not, then you have no effective protection. Three phase and a fourth wire. Does every wire make that short connection to the only earth ground - eitther direct or via a 'whole house' protector? Any one wire inside any cable that does not means ineffective building protection.
Either the wire makes that short connection to earth. Or it makes that connection via a protector.
I appreciate your confusion if this is the first time anyone has asked you what does protection Because an overwhleming majority foolishly think a protector does protection - and then promote the lie. An easily scammed majority will recommend a protector rather than learn about the only thing that does protection - single point earth ground. That means every incoming wire - no exceptons - make the always required short connection to earth.
If a doorbell wire out at the security gate does not get earthed before entering a building, then your building has ineffective surge protection. Then AC mains and telephone protectors have been compromised. Especially when using a Monster Cable protector that costs $500. Hopefully you are learning about the only item that does protection. It is not a protector. Unlearning lies promoted by myth promoters is difficult. Teaching reality to those educated by retail salemen can be extremely difficult.
melbourne architect
PostPosted: Apr 20, 2011 2:53 pm
Loyal Member
Loyal Member
re Safety Switches:
http://www.esv.vic.gov.au/Portals/0/About%20ESV/Files/Brochures/ESV_DL6pp(SafetySwitch)_SCREEN.pdf
The installer should check the house earthing when he installs the switch (try to get something in writing)
Cheap surge protectors have been known to catch fire (in one case, a Fire Station was burnt out; the red faced fireman later learnt it was due to the cheap surge protector/power strip in the office)
Mclaren
PostPosted: Apr 20, 2011 3:27 pm
We're building a new house and have gone for surge arresters - we have 3 phase power so that cost us 3 x $126 = $378 - not a lot of money in the scheme of things.
For info on our build: viewtopic.php?f=31&t=43093
Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!!
htennant
PostPosted: May 25, 2011 4:20 pm
Junior Member
Junior Member
We also went down the path of getting surge protection added at build time....as we are coming up to handover I was wondering if there was an easy way to check that it has been installed?
Cheers
Heath
http://nextstopdoreen.blogspot.com
nev25
 Post subject: Re:
PostPosted: May 25, 2011 10:20 pm
Junior Member
Junior Member
The Data Guys wrote:
. Fridges are now supposed to be on their own circuit
Absolute rubbish
Where did you get that from
westom
PostPosted: May 26, 2011 1:48 am
New Poster
New Poster
The protector itself does not do any protection. Protection is defined by the only item that does protection - earth ground. Is the protector properly connected? Only visual inspection can identify that. The protector that connects to AC mains must also connect as short as possible to the single point earth ground. Any sharp bends in the wire from protector to earth means compromised protection. Other mistakes to inspect for - no splices, that wire not inside metallic conduit, as short as possible (if it goes up over the foundation and down to earthing, then too long).
And it must be a single point ground. Every connection from every incoming cable must be that short (ie 'less than 3 meters') to the same earth ground. Obviously, protection increases if the earthing system increases. The protector does not do any protection. No protector does any protection. Earth ground is the most critical inspection. A protector is only as effective as the only thing that is doing the protection - the earthing system. Where inspection is important.
Your post implies you are still confused by the minor aspect – a protector. Overwhelmingly is the most critically important system component – earthing.
Users browsing this forum: No registered users and 1 guest
Read Article: How To Burglar-Proof Your Doors by 24hr-Security.com WAHow To Burglar-Proof Your Doors
The majority of devices mentioned in this report cost very little.…
Read Article: How To Protect Your Home From Intruders by 24hr-Security.com WAHow To Protect Your Home From Intruders
All doors in your home leading to the outside should have…
Read Article: How To Select A Burglar Alarm by 24hr-Security.com WAHow To Select A Burglar Alarm
Many types of burglar alarms can be obtained for residential use.…
Read Article: How To Burglar-Proof Your Windows by 24hr-Security.com WAHow To Burglar-Proof Your Windows
Many burglars enter homes by simply breaking glass windows. A good…
Watch Video: Technology Made Easy With Tuxedo Touch by Honeywell by Raging Technology SATechnology Made Easy With Tuxedo Touch by Honeywell
State-of-the-art home and building automation controller with built in web server,…
Watch Video: FE8171V Fisheye Network Camera - Multiple Display Modes by Raging Technology SAFE8171V Fisheye Network Camera - Multiple Display Modes
Watch the latest in camera surveillance. Multiple views from one…
Watch Video: VIVOTEK Advanced Techniques - Panoramic PTZ by Raging Technology SAVIVOTEK Advanced Techniques - Panoramic PTZ
Vivotek latest fisheye IP camera, see the power of what…
