May 24, 2013 11:50 amSign In50 members logged in
Building Forum » Building, Renovation & Maintenance » Safer Living
Bushfire areas - water tanks
New Topic Post Reply  Page 1 of 1
 [ 3 posts ]
Shaezy
 Post subject: Bushfire areas - water tanks
PostPosted: Feb 03, 2011 8:57 pm
Loyal Member
Loyal Member
Hi all,
We are required to have a 20,000L water tank on our property, of which 10,000L must be dedicated for fire fighting purposes. We also have to have the correct hose/pipe fittings for fire hoses, and a generator attached.
Does anyone else have this kind of tank? Do you need it close to the house or specifically near the road for easy access? Can it be sunk into the ground? Is such a tank different to a regular water tank (ie made from different material)?
I am going to contact the RFS to confirm details but would love to know if anyone has any experience with this. Thanks!
ledgend80
 Post subject: Re: Bushfire areas - water tanks
PostPosted: Feb 03, 2011 9:10 pm
Loyal Member
Loyal Member
hi there we have to have a minimum of 31500l concrete water tank with a conection point for rural fire brigade. we can put it where ever we want. I think you just talk to your tank supplier and thry will tell you what fittings you need.
Databoom
PostPosted: Feb 10, 2011 12:05 pm
Junior Member
Junior Member
we have to have 225000L, the best place to locate it (if you are using it to supply water to the house) is level with the house that way the pump can be a smaller one (less power), if you have to pump uphill then you will require a larger pump.
If fire fighting is the only requirement then nearer to the house would have to be a better idea (less distance to pump water), if you sink it into the ground the maintaining it might be difficult, and of course vehicular access is of premium importance because if the tank does not receive enough rain in the winter then a water truck will need access to fill it
Telecommunications systems, computer Networks and Security systems.
 [ 3 posts ]
Users browsing this forum: No registered users and 3 guests
Read Article: How To Burglar-Proof Your Doors by 24hr-Security.com WAHow To Burglar-Proof Your Doors
The majority of devices mentioned in this report cost very little.…
Read Article: How To Protect Your Home From Intruders by 24hr-Security.com WAHow To Protect Your Home From Intruders
All doors in your home leading to the outside should have…
Read Article: How To Select A Burglar Alarm by 24hr-Security.com WAHow To Select A Burglar Alarm
Many types of burglar alarms can be obtained for residential use.…
Read Article: How To Burglar-Proof Your Windows by 24hr-Security.com WAHow To Burglar-Proof Your Windows
Many burglars enter homes by simply breaking glass windows. A good…
Watch Video: Technology Made Easy With Tuxedo Touch by Honeywell by Raging Technology SATechnology Made Easy With Tuxedo Touch by Honeywell
State-of-the-art home and building automation controller with built in web server,…
Watch Video: FE8171V Fisheye Network Camera - Multiple Display Modes by Raging Technology SAFE8171V Fisheye Network Camera - Multiple Display Modes
Watch the latest in camera surveillance. Multiple views from one…
Watch Video: VIVOTEK Advanced Techniques - Panoramic PTZ by Raging Technology SAVIVOTEK Advanced Techniques - Panoramic PTZ
Vivotek latest fisheye IP camera, see the power of what…
