Browse Forums Increasing Home Value 1 Nov 24, 2015 8:39 pm Hi, I am new to this game and I'd really like some suggestions on how to update the exterior of our recently purchased highset 70s brick home. It is on a corner block, not too bad on the inside but very shabby and ugly on the outside. My thoughts include putting up a solid fence, replacing the guttering, painting the window trim, balustrade and garage doors and some landscaping but I'm not sure about colours and whether painting the garage doors will be enough or if they should be replaced altogether. Guttering is currently dark green. The roof is a shade of green but looks more grey. What to use if we replace the retaining wall? Anything else we could do? We probably don't have the budget to render unless we did it ourselves. We could maybe paint but I'm not sure how that would look. Link to image below (i couldn't figure out how to include it properly) Any suggestions would be much appreciated [img][img]https://farm1.staticflickr.com/614/22904555289_91801f4866_b.jpg[/img]our house by Cam, on Flickr[/img] Re: How to update the exterior of our ugly 70s brick home? 2Nov 28, 2015 9:28 pm Looks good! Retaining wall, if its rotted you could use treated pine again and dress it up by cladding it with decking boards. e.g similar to this( Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ) Other options are concrete, sandstone blocks, besa blocks, interlocking walls (e.g. versawall), rock walls etc. at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61686 Hi all, I am currently building through Simmonds and stuck deciding on my exterior cement roof titles and brick colours. The front and fascade of the house is a pretty… 0 2957 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7742 |
