Hi Guys,
I got my pre-approval from Wespack bank and I am still waiting for my land titling.
Can I change the lender at this stage?Because I feel Wespack rate are higher than other major banks.
Cheers,
Dane.
Browse Forums Increasing Home Value Re: Can I change the lender 2Apr 24, 2015 12:03 pm did you go through a broker or straight to Westpac? A broker will find you the best rate. there should be a cooling off period where you decide whether to use them or not....check the paperwork. Re: Can I change the lender 4Aug 04, 2015 11:51 pm We just signed up with Westpack for the land. We went through a broker. We are borrowing $207K and interest rate is 4.78% - The package we have chosen is Rocket Repayment. Once the land settlement is done, this will be combined into our construction loan, which should bring the interest rate lower. I assume in the areas around 4.5%. Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 36559 5 11143 2 3113 |
