Browse Forums Owner Builder Forum 1 Dec 17, 2018 9:54 am Re: Sub floor insulation 3Dec 17, 2018 3:56 pm aussieta going to use pet mesh (heavy gauge chicken mesh) Im leaning toward this too (bent up in same fasion as pic i posted), gonna be a prick of a job lol Re: Sub floor insulation 5Dec 17, 2018 7:34 pm aussieta i plan to install from under house using a staple gun just one long straight run will be a horrible job but a one off Sounds like you have timber, mines all steel Re: Sub floor insulation 7May 01, 2019 3:23 pm Just an update on this. So i have recieved my order, ended up choosing Bradford optimo system that uses plastic saddles that sit over the joists. Saddles are 45mm & my joists are 50mm and they suggested i break the saddles in half.. Decided against securing from bottom of josts as the gap between floor & batts will attract vermin such as mice & rats. https://www.bradfordinsulation.com.au/h ... gIRHPD_BwE Big weekend ahead Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29440 1 10522 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17649 |
