Browse Forums Owner Builder Forum Re: Pre-cast Concrete House Build Perth 41Nov 30, 2020 8:30 am Your build will need to meet the NCC and it will be certified by a building surveyor. Alternate solutions can be provided by engineers and then certified by a building surveyor If your construction is not covered within the NCC Then solutions are designed according to the relevant Australians Standards, ie, As3600 Concrete Structures, As3700 masonry Structures, As1720 Timber structures, etc by engineers only NOTE there are no AS for Polystyrene structures. Building surveyors approved those polystyrene houses, why, because they are built overseas ? Polystyrene houses built in Africa ? Where's the engineering data and proofs? Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Pre-cast Concrete House Build Perth 42Dec 02, 2020 3:06 am The polystyrene is purely for insulation purposes and is not structural in my design. The outer concrete is also purely a protective wind/water and thermal cladding effectively , and is also of no great structural benefit ( although it would obviously stiffen the wall as compared to only the single structural wryth. I have had a look at those foam blocks, interesting alternative if you want to use concrete for a stronger build than traditional materials. We have a couple houses in my area that were built using the concrete foam blocks, and concrete tilt panel, and also one made of smaller pre fab'd concrete panels. Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 14017 We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13997 |
