Browse Forums Owner Builder Forum 1 Nov 27, 2017 2:40 pm Hi, We are looking to see if anyone has had trouble with their large format tiles on a steel floor. We are at lock up and have yellow tongue down already, we were looking at putting tile underlay on top than 600x600 tiles. A couple of tilers have said that it not an issue, one has been on site, however other tilers that I have spoken to have said that tile and grout cracking might be an issue. Obviously we need to tile the bathrooms and laundry but we have a 90sq area that would look awesome with larger tiles. Anyone had a similar situation? Thanks! Jude Re: Tiling on Steel Bearer/Joist floor 2Nov 28, 2017 9:15 am Yes that is correct Tile and grout cracking will be an issue if there is excessive Deflection, movement, expansive and contraction of the steel frame,etc You can design & place control or movement joints but you should have looked at that before the flooring went in Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Tiling on Steel Bearer/Joist floor 3Nov 28, 2017 11:26 pm Aren't you supposed to attach OSB to the steel frame first and then attach underlay and tiles to the top of OSB? Steel's thermal expansion coefficient is around 2.5 higher than wood/pine, so even if steel decides to expand, engineered wood (your yellow tongue) should be holding it up in some way? Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not… 8 9560 Hi Mrboh Just wondering if you have any BAL or flame zone issues on your block, as getting compliance with BAL requirements whilst doing bearers and joists is tough. Not… 1 8791 Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 32556 |
