Browse Forums Owner Builder Forum Re: Can you change your plans? 2May 14, 2017 10:30 pm Berek Can you modify the layout of the kitchen and/or bathrooms between getting a DA and submitting building plans? The location and size will be the same just moving the items within. You would need to talk to your builder. But generally before they lodge the DA, most builders do a DA check. If you can get in there prior to submission you might have a chance however some builders won't allow you to change the plans. Kind Regards, Bruce "Building an Eden Brae Waldorf 50 in North Kellyville" Blog: http://waldorf50.blogspot.com.au A Mobile Solicitor at Wong & Horta Lawyers Website: http://www.whlawyers.com.au Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 15045 The plan (excuse the pun) ideally is to do just that and take the basic floor plans and elevations that we have bought and have a draftsman replicate them to comply prior… 2 760 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 36602 |
