Browse Forums Owner Builder Forum 1 Mar 19, 2017 4:43 pm Hi We are building a house out in the sticks, no gas or running water, no sewarge so we will require septic tank and tank for drinking water etc. We are starting to look at whether we should go all electric throughout entire house for heating cooking etc, or should we get a big gas bottle and go 50/50? Any thoughts would be welcomed. Rgds Steve Re: Owner building out of surburbia, need help 2Mar 19, 2017 5:10 pm scdc Hi We are building a house out in the sticks, no gas or running water, no sewarge so we will require septic tank and tank for drinking water etc. We are starting to look at whether we should go all electric throughout entire house for heating cooking etc, or should we get a big gas bottle and go 50/50? Any thoughts would be welcomed. Rgds Steve I would go 50/50 with gas. I lived in the middle of nowhere growing up and it was always a security with if one went you always had the other. Gas was used for heating water and cooking. Re: Owner building out of surburbia, need help 3Mar 19, 2017 5:19 pm Bottled gas is about the most expensive and least efficient fuels in Australia. Check out this link: Bottled Gas In your situation I would go for electic, Possibly solar if the cost of an electric connection was too much The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Owner building out of surburbia, need help 4Mar 19, 2017 8:39 pm I would have solar hot water service, bottled gas for cooking & wood for heating. I have found that one bottle of LPG for cooking only lasts me 3 years.(the rental charges on the bottles are higher than the actual gas charges) Where I built is in a remote part of the country and the restoration time for electricity after a power failure is 2 to 3 days Fire wood for space heating in the country is free, one just has to chop it up, stack it and dry it. I found the Utility connection charges for an all electric house in a remote location is very expensive. Re: Owner building out of surburbia, need help 5Mar 19, 2017 11:34 pm We currently use only tank water, have a septic, use a wood fired heater and use LPG for gas and HWS. LPG costs increase all the time as does electricity. Our next house will be independent of any utility (gas, water, elec, sewerage). We will have an all electric house powered by solar and batteries (& a small generator for emergencies). We will retain our gas BBQ and gas camping gear so in an emergency these can be also be used. If everything fails and we have no electricity or gas then my view is simply BIG DEAL, ADAPT & GET OVER IT. So that's our approach and if you and your family are also that way inclined I recommend the same for you. Hi VK, Think it's worth investing time in an Owner Builder course to equip you with basic knowledge on Australian Building Industry and its regulations. Also, I suggest… 11 22767 While i was across this behavior's pre appointing my (the builders) surveyor, I did tell the builder i was aware what they were doing and while i disagreed with it, they… 13 14590 |
