Browse Forums Owner Builder Forum 1 Feb 08, 2017 12:41 pm hi, I would like to convert my current garage to a granny flat. I am a solid slab in the garage that I want to make use of it. Any suggestion on where to start? Or do you know anyone who can inspect my current slab and certify if it fits for the Granny purpose? Re: Convert Garage to Granny Flat 2Feb 11, 2017 6:22 pm A couple of items to consider: Was a damp proof membrane put under the garage floor? What, if any termite protection was installed under the garage floor? How high is the top of the garage floor above finished pavement level? 75 or 100mm is usually the minimum required for a dwelling Installing vapour barriers under the roof and in external walls could be tricky unless the external cladding is first removed (temporarily). I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4094 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13880 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7176 |
