Browse Forums Owner Builder Forum 1 Nov 10, 2016 7:05 am Morning all, Just had my final inspection done on my 3 years of work and I have been told to replace the polycarbonate roofing on my decking with something that is BAL 19 rated. I was tol there is a product similar to polycarbonate out there that is rated to BAL 19. I cant find it. Anyone got any great ideas as it looks like my other option is glass as I want it clear due to it being south facing and having windows into bedrooms under the verandah. Thanks in Advance Kent Re: Polycarbonate roofing and BAL 2Nov 16, 2016 7:44 am Kent, as you've discovered polycarbonate type roofing does not meet the current flammability requirements for any designated bushfire prone areas. Nearly all the testing & certification was done prior to the aus standard being updated. I haven't found any manufacturers that can comply, so if you find a product I'd be interested in the details. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Hi Simeon, Thanks for your reply. Yes, that makes sense. I contacted the manufacturer; they will issue a certificate with BAL rating mentioned on it. 2 1848 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 3760 |
