Browse Forums Owner Builder Forum Re: Cladding 2Jun 21, 2016 7:20 pm I can't help you specifically as I am not based in QLD, but on my build I found the best source of steel cladding/roofing materials was general steel merchants (not retail hardware stores) These steel merchants can often provide a design service to measure quantities, lengths etc and also supply all the other materials you will need such as speciality fasteners, brackets, flashings (over and under), purlins, insulation, silicone etc. http://forum.homeone.com.au/viewtopic.php?f=38&t=71081&start=180 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12072 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11124 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5659 |
