Browse Forums Owner Builder Forum Re: excavation and retaining wall approximate costs 3Apr 11, 2016 11:00 pm Yep, a shipload should cover it! 360m3 is heaps. Down here a "cheap" rate is $50/tonne for transport & dumping of soil, that's not including the excavation, you'd be looking at machine hire for that so maybe $500-$1000 per day. The retaining wall is going to be a challenge. Not the length, the height. Normally you go down as far as you go up Re: excavation and retaining wall approximate costs 4Apr 12, 2016 10:02 am A dozer will cost about $1,000/day plus transportation to and from the site. Digging is the cheapest part. These days off site disposal is expensive so if possible use cut and fill to eliminate off site disposal costs. A 4m retaining wall will cause problems for you. It will need to be fully engineered, have water diversion drains and may need to be fenced (as fall protection). I suggest that you consider terracing by having say 3 changes of level. Alternatively, if you are excavating into rock or sandstone you may need to do nothing, Just batter back the excavation and eliminate the retaining wall. Also have a soil test done including drilling some deep core holes to try and find out what surprises lie under the ground. Re: excavation and retaining wall approximate costs 6Apr 20, 2016 10:43 pm My retaining wall 22 metres across 2.1 metres high, then turns at both ends of block starting 2.1 metres high and ending one foot high 10 metres later for both sides of block, cost $20, 000 and obviously enginered. We just had a pool dig and was told by our contractor the pool would need piers. They spoke to the engineer who advised the piers would need to be concrete. When the… 0 943 No one can give you a meaningful answer without looking at your building contract, what happened on site and who designed your house You should get experienced building… 1 10302 Hi there, We’ve recently had plans approved to add a 1st storey addition to our existing house for a growing family in Sydney. With the current cost of building… 0 4740 |
