Browse Forums Owner Builder Forum Re: Oregon or pine for structural timber 2Apr 14, 2015 1:30 pm We had a house built using Oregon, the exposed timber rotted. Can't tell you if the actual frame did or not, the bit we saw after it had been up for around 20 years was fine. BUT.... I would use treated pine. Are you in an area with European House Borer? Worth looking into, you may find steel is the best choice. DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6592 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52859 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10976 |
