Browse Forums Owner Builder Forum 1 Oct 18, 2012 4:26 pm We're about to start on a steel frame kit home from Australian Garage Supermarket. I've been advised by someone to use purlin tape to prevent the "cracking" or "bang" associated with steel frames (caused by temperature variances). Apparently the tape is foam backed with a teflon type surface on one side which allows slip and stops sudden movement. Has anybody used this tape and can describe exactly where and how it's applied? Also, where to source it. John Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14447 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8026 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4458 |
