Browse Forums Owner Builder Forum 1 Mar 03, 2011 9:24 am Re: How would you fix this hole in the door? 4Mar 03, 2011 10:05 am New door if you want to retain the venneer look, stick a large plaque or coat hook over it on a batten (if at the right height) or you could fill with builders bog, sand & paint the whole door cheers Re: How would you fix this hole in the door? 5Mar 03, 2011 1:03 pm Thank you all. How much do you think they would deduct from our bond if we leave the door as it is? Re: How would you fix this hole in the door? 6Mar 03, 2011 2:34 pm blueblueblue Thank you all. How much do you think they would deduct from our bond if we leave the door as it is? As much as it costs to fix it. No more no less. Which may be $400 - $500 once you buy the door have it hung and painted. Maybe a bit more. Why not call a local handyman and get a quote? Maybe you can source a similar door from a Salvage yard? Still needs to be fitted properly but at least you will have the same door as looking at that looks like a 1960's or '70's number and it may be very hard to match the same timber with a door off the shelf PS: Who got angry? https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: How would you fix this hole in the door? 7Mar 03, 2011 9:22 pm should be able to get a door off ebay for under $20. Or you could ring some demolition yards to see if they have any. The should have something that will look close to what is there. Then a handy man to re mount it. Might need a clean up on the hinge side and also to patch the hole in the jamb. You'll have to make a new hole in the jamb for the striker. Re: How would you fix this hole in the door? 8Mar 04, 2011 6:08 am any half decent hardware supplies shop should carry these doors, espescially if they supply the trade, should be about $50, your problem will be to match the varnish finish, it will most likely look different to the esisting doors even with taking the best care. I'll take a guess & say $375-400 from the bond woodchip Re: How would you fix this hole in the door? 9Mar 04, 2011 10:18 am Woodchip stick a large plaque or coat hook over it on a batten can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 5568 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 26734 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 9154 |
