Browse Forums Owner Builder Forum 1 Feb 27, 2024 11:46 am Hi all I doing a shed/house that has been engineered for this purpose and being built on a slab on the ground. The total size including the awnings is 18 x 30 it’s got 3m awnings on the long sides and a 5m awning at the front. Interior house is 12 x 25m. It is basically two flats half for me and half for my daughter. The questions I have are 1. We are using corrugated metal roofing for the interior ceiling with anticon blanket underneath the roof do I need additional insulation. 2. The interior wall frames are not structural so is there a need for structural timber and can I use 90 x 35 untreated Thanks in advance for any help Re: Shed conversion 2Feb 27, 2024 2:56 pm If you are building a house then you will have a building permit, full set of approved plans and specifications, read it, why are you asking questions here? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Shed conversion 3Feb 27, 2024 5:31 pm building-expert If you are building a house then you will have a building permit, full set of approved plans and specifications, read it, why are you asking questions here? Because it only states 90mm not if it’s 45mm or 35mm and yes I do have the plans my question was specifically since it’s not the structural value and only to hold the internal wall cover could I use 35mm so unless you have something to add in way of an answer thanks for your reply From the information posted it looks to me your rumpus room is nothing more than extended garage. That will present a number of challenges. Single brick wall between… 2 8028 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11631 I have an early 90’s built home where the garage is connected to the house under the existing roof. The garage already has gyprock ceiling and two windows. Would this be… 0 3146 |
