Browse Forums Owner Builder Forum 1 Aug 08, 2023 10:35 am Hi, I am no structural engineer, but work in engineering. I have a concern about the Structural Engineering for my granny flat first floor. It has a 728mm cantilever. The engineering drawing has a single 5.45m long LVL. Does not look too strong to me. I attached my "suggestion". I know, more work and more hangers... Are there any structural engineers out there that can tell me if I should be concerned? Or will the original 5.45m long LVL by OK?
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Concerns about strengh of Engineering Floor Joists 4Aug 08, 2023 12:34 pm can you mark on your first drawing where exactly the first floor wall will be over your cantilever? I think you are correct it needs to be strengthened if first floor is not exactly over the ground floor wall. Re: Concerns about strengh of Engineering Floor Joists 6Aug 08, 2023 5:37 pm Before you get a building permit your relevant building surveyor will need to be satisfied about the engineering. Most likely form 14 certification by an independent(second) structural engineer will be asked for. If your structural design is certificed by two structural engineers you should be OK Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Concerns about strengh of Engineering Floor Joists 10Aug 14, 2023 1:34 pm Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor joist design. My concern is that the left 5.4m LVL is too weak. It will carry whole top floor and roof. Will my suggestion be a good idea, and make it stronger? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Houses have been framed on floor joists since settlement, chipboard flooring is only around for 50 years or so, so why would it not be satisfactory? However exercise skill… 3 17123 Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 32260 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7360 |
