Browse Forums Owner Builder Forum 1 Nov 22, 2022 9:50 am I am currently building a house in Bali. There is a wall from the carport to the garden which is planned for a double wooden door. The width of the doors is 1100mm. To go through one side only would be very narrow so both doors would need to open each time. Even if we could get a lock to manage this (top and bottom bolts automatically) this would soon become a pain. Any ideas on other options ? We want something that looks nice on both sides but a traditional Balinese solid wooded door would be too heavy hinged on one side only (according to our builders). Any suggestions would be gratefully received. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Wooden door width 2Nov 22, 2022 1:28 pm if for some reason you cannot get a single panel door for the whole opening, another option would be to put a narrow fixed window panel next to a door panel. so your door panel doesn't have to be as wide. another alternative is to keep two door panels as you are thinking, but make them different width. that way you only have to open 1 larger panel to walk in, and you'd only ever open the second narrow one if you needed to bring something wide in. saves you the hassle with the locks too, as you'd only need manual bolts into the top and bottom for the narrow part. Re: Wooden door width 3Jan 01, 2023 12:38 pm Googling traditional Balinese doors - I see many of them have ornate carved panels either side and sometimes above the door. This would be a relatively easy solution by commissioning 2 panels for a standard single Balinese door. Alternatively, with 2 narrow doors perhaps a strong piano hinge joining them would make opening a bi-fold door easier? Thanks again for this information. If you do hear anything different, would be great to know 4 8905 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 5119 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 10426 |
