Browse Forums Owner Builder Forum 1 Oct 11, 2022 6:46 pm I'm currently in the planning stages and trying to decide the best method to instal the Vergola to my new house. Would you recommend the frame be bolted directly to a house wall (brick) or fixed to rafter brackets, which anchor into the roof trusses, and protrude through the fascia? Re: Vergola - bolt to house wall or fix to rafter brackets? 2Mar 23, 2023 8:54 pm Hi there, not sure if you have resolved this already. both are suitable options and depend upon on your preference. Fascia brackets generally carry the same height as your eave (in fact louvre roof might end up sitting slightly higher) which is generally preferred. It is however more complex and then you might have to also think about covering the fascia brackets from underneath so you don't see them when standing underneath. By bricks I presume, you are referring to brick wall underneath the eave. This can be a good option if the floor height is decent e.g. 3m and there is enough room to install the new beam. hope this helps ps: FYI I work for a louvre roof company. Old Home Restoration / Renovation Cheers mate! This is exactly what I was thinking but wasn't sure if it was something I'd find on the shelf. I agree with you, fixing the brackets to the board will look… 2 4007 Building Standards; Getting It Right! When my house was built (over 7 years ago), the post brackets were done to allow for concrete porch, but they didn’t allow for the planned stone paving. I’m finally… 0 2085 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 9105 |
