Browse Forums Owner Builder Forum 1 Sep 13, 2021 12:29 am I am doing a custom build. Just wondering if anyone can help me with the idea how we can achieve a recessed pelmet system in the ceiling as attached photo? Does it mean we have to drop the ceiling? If yes, how much? or it can be achieved by any adjustment of the joist or roof trusses etc.? Also how much width we need to leave for the sheer curtain and block out curtain to accommodate inside that recessed portion? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Recessed Curtain Pelmet in the ceiling 2Sep 13, 2021 2:07 am This is done using two level ceiling concept, where you install a structure of metal profiles and furring channels (in the shape of your ceiling) and then attach gyprock to them, depth will be at least 10 cm, sometimes all the way up to 30 cm. You can also install some nice looking lighting strip into the same recess too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Recessed Curtain Pelmet in the ceiling 3Sep 13, 2021 3:07 am alexp79 This is done using two level ceiling concept, where you install a structure of metal profiles and furring channels (in the shape of your ceiling) and then attach gyprock to them, depth will be at least 10 cm, sometimes all the way up to 30 cm. You can also install some nice looking lighting strip into the same recess too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Did you mean having a 100mm drop ceiling and then having that gap near the wall where the pelmet can fit? What is the width required for both sheer and black out curtain? Re: Recessed Curtain Pelmet in the ceiling 4Sep 14, 2021 7:31 am boneym I am doing a custom build. Just wondering if anyone can help me with the idea how we can achieve a recessed pelmet system in the ceiling as attached photo? Does it mean we have to drop the ceiling? If yes, how much? or it can be achieved by any adjustment of the joist or roof trusses etc.? Also how much width we need to leave for the sheer curtain and block out curtain to accommodate inside that recessed portion? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We built a bulkhead to match the cornice and then installed the curtain behind it. Re: Recessed Curtain Pelmet in the ceiling 5Oct 03, 2021 6:28 pm You could also set a track into your ceiling lining or design your ceiling to frame out the curtain recess. There’s a number of options depending on what stage your at. What stage are you at? Re: Recessed Curtain Pelmet in the ceiling 6Oct 03, 2021 8:06 pm Bimbob You could also set a track into your ceiling lining or design your ceiling to frame out the curtain recess. There’s a number of options depending on what stage your at. What stage are you at? My building construction is going on. Haven't done the ceiling yet. So need to understand If there is anything we should do in this stage to have recessed curtain. Re: Recessed Curtain Pelmet in the ceiling 7Oct 04, 2021 8:01 am the easiest option for you (and cheapest) at this stage is to install it in this fashion. https://www.blindspace.com/recessed-curtain-tracks Re: Recessed Curtain Pelmet in the ceiling 10Feb 28, 2023 6:52 pm JB1 I have them. Recessed so they go into the ceiling space. Note, you likely need to design it at engineering stage as your roof or posi truss will get in way. Any tips for someone who would like to have this done in their current home that's already been built? Does this require me to tear down our current roof and recessed lighting? Re: Recessed Curtain Pelmet in the ceiling 11Feb 28, 2023 9:44 pm nunelus JB1 I have them. Recessed so they go into the ceiling space. Note, you likely need to design it at engineering stage as your roof or posi truss will get in way. Any tips for someone who would like to have this done in their current home that's already been built? Does this require me to tear down our current roof and recessed lighting? Re: Recessed Curtain Pelmet in the ceiling 12Feb 28, 2023 10:51 pm JB1 nunelus JB1 I have them. Recessed so they go into the ceiling space. Note, you likely need to design it at engineering stage as your roof or posi truss will get in way. Any tips for someone who would like to have this done in their current home that's already been built? Does this require me to tear down our current roof and recessed lighting? Cool! Can you also add lighting to a bulkhead? (What exactly is a bulkhead lol?). I can't tell the difference from pictures between a bulkhead and a regular recessed curtain pelmet. Does it have something to do with putting up some sort of crown molding? Recessed Curtain Pelmet in the ceiling 13Mar 01, 2023 11:06 am See this photo https://trowelcraft.com.au/wp-content/u ... 24x768.jpg You can put lighting behind or under the bulkhead You could make the bulkhead wider and place cornices between the ceiling and bulkhead It’s fairly common Also check out Waldorf’s post above Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling… 6 2819 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6524 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2571 |
