Ours is 2700mm x 1585mm. 2400 is over and above standard so I am sure your door will look amazing and will be a talking point.
Browse Forums Owner Builder Forum Re: OB in Hume area - VIC. Fast forwarded + photo heavy 181Apr 03, 2016 7:23 pm Building4my3tots What size is the door? We should of did full height 2700, but it was too late. Ours is 2700mm x 1585mm. 2400 is over and above standard so I am sure your door will look amazing and will be a talking point. = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 182Apr 03, 2016 7:29 pm kasra nedlands Haji!! You have done so well!! Your almost there. I love everything about your house. It's obvious you have put a lot of thought into it. Can't wait to seen the finished kitchen!! Thanks Kasra, looking forward to not having to make any more decisions. While I have tried to stay positive the whole time I think the most stressful thing for me was having to constantly make choices, especially on the spot. The kitchen is the heart of the house and is looking fantastic. Once all the ovens, cooktops, tap, bench lighting and final touches are all done that's when I will reveal it = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 183Apr 03, 2016 7:30 pm deejay08 looks amaze! Can't wait for the final reveal! The pool surround is genius! Thanks DJ = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 184Apr 05, 2016 12:39 am Very Nice, the external finish looks high quality. Re: OB in Hume area - VIC. Fast forwarded + photo heavy 187Apr 05, 2016 7:31 pm Thanks for all the compliments. Received the front pivot door with its jamb today. We hadn't seen a sample of it as we just supplied the timber to the door maker and hoped for the best (we had agreed on the location of window which is yet to be installed) but we're pretty wrapped about how it has turned out. Just needs a coat of oil after installation. Doesn't look too large now as it's laying on it's side but will be the same size as the hallway sliding door, measuring 1500mm x 2700mm. It is a heavy door but due to the pivot system (no hinges on the side) it is easy to open and also closes softly - even if you were to slam it, eliminating any possibility of someone squashing their fingers. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We will also install this August smart lock which allows you to enter the house without keys similar to a keyless entry system on cars, as well as allow access remotely while you're away. Suffice to say it looks awesome and should go well with the door. Just need to find a push/pull handle to suit. More on the smart lock: = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 188Apr 05, 2016 8:12 pm Haji Thanks for all the compliments. Received the front pivot door with its jamb today. We hadn't seen a sample of it as we just supplied the timber to the door maker and hoped for the best (we had agreed on the location of window which is yet to be installed) but we're pretty wrapped about how it has turned out. Just needs a coat of oil after installation. Doesn't look too large now as it's laying on it's side but will be the same size as the hallway sliding door, measuring 1500mm x 2700mm. It is a heavy door but due to the pivot system (no hinges on the side) it is easy to open and also closes softly - even if you were to slam it, eliminating any possibility of someone squashing their fingers. We will also install this August smart lock which allows you to enter the house without keys similar to a keyless entry system on cars, as well as allow access remotely while you're away. Suffice to say it looks awesome and should go well with the door. Just need to find a push/pull handle to suit. More on the smart lock: Hi Haji, Doesn't the smart lock have the US voltage system and is not yet configured to Australian standards? I was actually looking to invest in something like this and found this to be the case with the August smart locks. Re: OB in Hume area - VIC. Fast forwarded + photo heavy 189Apr 05, 2016 8:45 pm By the ways what wood have you used for this
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://s1376.photobucket.com/user/gable ... sort=3&o=0 Re: OB in Hume area - VIC. Fast forwarded + photo heavy 190Apr 05, 2016 8:46 pm gablesrocks Hi Haji, Doesn't the smart lock have the US voltage system and is not yet configured to Australian standards? I was actually looking to invest in something like this and found this to be the case with the August smart locks. I believe it's just battery operated which notifies you via the app as well when the batteries are low, no electrical wires to connect. Re: OB in Hume area - VIC. Fast forwarded + photo heavy 191Apr 05, 2016 8:52 pm gablesrocks It's blackbutt in rough sawn finish. We'll also be using the same timber to clad the dining wall where the door is leaning on, so when you open the door you'll see the same feature there, and we'll also have the same timber on the pool side. Re: OB in Hume area - VIC. Fast forwarded + photo heavy 192Apr 05, 2016 8:54 pm Haji gablesrocks It's blackbutt in rough sawn finish. We'll also be using the same timber to clad the dining wall where the door is leaning on, so when you open the door you'll see the same feature there, and we'll also have the same timber on the pool side. I have no words to describe your choice! It is absolutely stunning! I can't wait to see the wall and pool area now. Re: OB in Hume area - VIC. Fast forwarded + photo heavy 193Apr 05, 2016 10:08 pm I'm sold!!! August smart finally a simple aesthetic solution. Have you got yours yet? If so does is feel well made? Re: OB in Hume area - VIC. Fast forwarded + photo heavy 194Apr 05, 2016 10:19 pm kasra nedlands I'm sold!!! August smart finally a simple aesthetic solution. Have you got yours yet? If so does is feel well made? I should be getting it Thursday hopefully. Haven't felt it but looks quite chunky which I like, I think it will suit a door our size very well. = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 197Apr 06, 2016 9:06 pm kasra nedlands I'm sold!!! August smart finally a simple aesthetic solution. Have you got yours yet? If so does is feel well made? Kasra, received our smart lock today. Definitely chunky and feels good in hand. Probably expected it to be a little heavier but still great as it will be fixed on the door, won't be carrying it around. Should be installing front door tomorrow hopefully so will install that as well. = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 198Apr 06, 2016 10:53 pm waxinggibbous Does the August SL also have a key entry in case anything goes wrong with the batteries or electronics? (I'm wondering if that is what the little circle on the front is?) We have decided to mount it on the inside of the house so we can still use the key in case anything goes wrong. Door should open up as we walk to it from the outside but I would prefer to keep it on the inside to reduce the risk of it being pinched as well. Plus we would see it more often from inside the house = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 199Apr 06, 2016 10:58 pm gablesrocks I have no words to describe your choice! It is absolutely stunning! I can't wait to see the wall and pool area now. deejay08 That door is stunning! You're killing me with your selections! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 200Apr 06, 2016 11:02 pm Good choice on the August. It is ment to go on the inside. They have also released a cam and keypad (these go outside). I don't think they look as good as the lock. Be prepared to spend a bit of time setting it up to get it to work exactly as you want. Using my LG-G4 to bring you this update. Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5796 What size are the windows, double or single glazed, can I have a pic of the full windows inside & out? If you can see packers please take a pic. 1 12590 |
