Browse Forums Eco Living Re: Plumbing consultant / Hydraulic engineer recommendation 3May 27, 2020 12:15 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Plumbing consultant / Hydraulic engineer recommendation 5May 27, 2020 5:42 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Plumbing consultant / Hydraulic engineer recommendation 8Jan 19, 2021 9:45 am For cold water, just normal branch distribution. For hot, I decided to go down ring main path as it seems more cost effective. I will however put in a water recirculator pump and have it under smart control (on demand as well as pre-set times) so it doesn’t act as a radiator all day long, all year round. 3 6662 The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 9864 just ask a carpenter/ builder, if they are unsure they will get the engineer to advise. 1 1535 |
