Browse Forums Eco Living 1 Jun 02, 2014 9:18 pm what size pump would l need that will give me mains pressure.l am installing a 33,700 litre tank Re: water tank 2Jun 02, 2014 9:39 pm Most if not all pressure pumps will achieve mains pressure but the key is what flow volume do they need to deliver. There is some advice at this link about pump selection http://www.anewhouse.com.au/2013/06/rai ... pump-size/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: water tank 3Jun 02, 2014 9:46 pm Thanks for reply.would 25 litres per minute be ok for gardens.i have mains water for house. ( husband is overseas) up to me to try and sort it out. Re: water tank 4Jun 02, 2014 11:05 pm pattycake4 what size pump would l need that will give me mains pressure. Maximum mains pressure is now mandated as a maximum of 500 kPa but many new houses are as low as 400 kPa. Why do you want mains pressure? pattycake4 would 25 litres per minute be ok for gardens. I take it that you are referring to the delivery flow rate at the end of the hose rather than the pump's flow rate as per its flow chart. To give you a guideline, the common garden sprinkler at the end of a standard length (15 metre) 12 mm garden hose attached to a mains water tap will flow at 18-20 litres per minute. Don't get confused by a pump's pressure, head and flow rate as per the pump's flow chart. When selecting the size and type of pump, you need to consider... How far from the tank will the pump be? What are the intended uses that the pump will need to satisfy? GARDENS Size of garden and distance from pump. Watering method...will it be hand held on/off constant watering or mainly a sprinkler? Car washing? Distance to driveway? Windows etc? EDIT: One of the best articles about pumps that I have ever read is on an eBay site!!! (I have no connection with the seller). It is easy to read and gives heaps of information. See below. http://www.ebay.com.au/gds/Choosing-a-W ... 099/g.html You will also need advice about the tank's plumbing. (Separate thread). 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: water tank 5Jun 03, 2014 4:16 pm thank you for you help,most useful.l will have a read of article,will workout distance from pump etc .then l will ask for more information Re: water tank 6Jun 03, 2014 7:38 pm Any reputable constant pressure pump (not constant flow type) is probably adequate for most single storey construction. For 2 or 3 stories you should get professional advice as the higher the head the lower the flow. Some specialist pump suppliers may provide this technical advice for their customers. Re: water tank 7Aug 27, 2014 7:09 pm l have a quote for rainwater tank.Do you think pump is right size, grateful to any imput on setup etc Supply and install 1 new 31700 litre polymaster rain water tank Upgrade of existing 4x2 Colourbond down pipes to 90mm PVC down pipes for wet drain feeding rainwater tank Supply and install new 100mm gate valve on existing stormwater drain to allow for easy cleaning and maintenance of wet drain (charged drain). connecting existing stormwater drain into rain water tank. Over flow to discharge on ground approx. 2 metres away from tank Supply and install new LOWARA HM/HMS series pump and pressure control. Pump supplies 70 litres a minute at 400kpa of pressure or 57Psi of pressure Pump is designed to supply sufficient water supply to taps as discussed and allowance for a garden hose of approx 20 metres off each tap. Pump is also designed to keep a constant supply pressure when all taps are operating at the same time Includes pump base and cover in same colour as tank Supply and install and excavate for new polly water line from pump to 3 taps located in various places around property as discussed and provisions for connection of dripper line for garden includes distribution pit for solenoids. Supply and install 3x 3/4 copper upstands to 3/4 bib taps with hardwood post levelling of ground and 100mmx250mm hard wood sleeper frame including 150mm of compacted blue stone dust for tank base. Tank base will be installed to a 98% compaction rate Please allow an extra 2200 for a concrete base for tank concrete base will be a min 150mm thick at 32mpa concrete strength with f82 mesh Concrete slap needs to be able to take a weight of min 33 tons NOTE: Works are subject to storm water drain passing pressure test. 10% deposit is required on day of works $1239.00 Note Please allow 3-4 weeks for order and delivery of tank If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 18203 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11495 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 2146 |
