Browse Forums Eco Living 1 Jan 03, 2013 11:40 am I'm contemplating just how much you guys are spending on boosting throughout the year? hopefully after some responses from Sydney... from what I've been reading the http://www.apricus.com.au/ systems looks quite good and I'm curious how I can convince my S.O we should spend a few dollars getting one Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: How are you guys finding Evacuated Tube hot water system 2Jan 03, 2013 1:36 pm My dad has one. He lives in WA and has had a nightmare of a time getting everything installed. He ended up having a friend from Germany coming over and installing the tank system for him (it's been a saga, don't want to rehash everything). From a technology point of view it's an excellent system, he had trouble with the practical installation and customer service side (getting a local plumber who could do the work for example). I think if you were in Sydney, close to the company it would be much better. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14819 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20658 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25067 |
