May 22, 2013 7:34 pmSign In60 members logged in
Building Forum » Lifestyle » Eco Living
Ozzi Kleen systems
New Topic Post Reply  Page 1 of 1
 [ 6 posts ]
Missshay
 Post subject: Ozzi Kleen systems
PostPosted: Jun 09, 2012 5:50 pm
New Poster
New Poster
We are building a new house on 17 acres, I've just started looking at greywater treatment systems.... Has anyone installed a Ozzi Kleen system in Victoria? Or any suggestions on a good system as I'm not sure which to look into further.
paulw11
PostPosted: Jun 09, 2012 8:13 pm
Hi
I think they are all much the same. I ended up using an enconocyle after asking for a recommendation here from someone who is in my area. Hopefully someone in Vic can help you out, Although enconocycle should have a local representative - they are pretty popular
Paul
5 acres in Hartley, NSW
Our House Blog
Missshay
 Post subject: Re: Ozzi Kleen systems
PostPosted: Jun 09, 2012 10:24 pm
New Poster
New Poster
Thanks Paul, I'll have a look :)
RocksInHead
PostPosted: Jun 09, 2012 10:48 pm
Loyal Member
Loyal Member
On 17acres I would just use a standard septic with a sand filter and distribution bed. Easy to install, generally only has one pump (subject to the lie of your land) and that pump only runs when there's liquid to distribute.
A fair number of the aerobic systems have 2 pumps and an aerator. They can be noisy as the aerator can run 12-24 hours a day depending on the brand and with 3 motors, use considerably more power. I believe that most aerobic systems also require quarterly inspections.
Anyway...something to consider
Regards
RiH
Missshay
PostPosted: Jun 10, 2012 7:17 am
New Poster
New Poster
Thats a really good point!
I was worried about the noise. :( Maybe I could have a normal septic and a greywater system for our other water waste....... Or is that not how it works ???
Are there many down falls of installing a greywater system just for normal water waste ?
I really appreciate everyones comments, it helps a lot :)
indi
PostPosted: Jun 27, 2012 12:47 pm
Loyal Member
Loyal Member
We have had both an Ozzi Kleen and Septech (as well as septic tanks). A lot of councils will insist on a treatment plant rather than a septic, check this out first.
Of the 2 systems we had far less trouble with the Ozzi Kleen, we always seemed to have to get the Septech bloke out as the alarm would trigger and we could not turn it off. The only service visit we had for the Ozzi Kleen was when we left the bath running to flush to water main (took nearly 6 hours before the water stopped running red), the water level alarm tripped. The OK was also a lot quieter than the Septech.
Both needed 1/4 inspections.
 [ 6 posts ]
Users browsing this forum: No registered users and 4 guests
Read Article: Solar Energy FAQ by Go Lights NSWSolar Energy FAQ
Complete and comprehensive Solar Energy and lighting FAQ
Read Article: Outdoor Lighting Glossary by Go Lights NSWOutdoor Lighting Glossary
A description of the popular types of outdoor lighting
Read Article: LEDs - what you didnLEDs - what you didn't know!
You know how hot incandescent bulbs become. That's because they convert…
Read Article: Is your home Conducive to Termites? What to look for.. by Victorian House Inspections VICIs your home Conducive to Termites? What to look for..
Termites can cost you thousands of dollars in repairs and heartache.…
Read Article: AustraliaAustralia's Only Custom Hydrotherapy Spabath Systems
Roundbathcompany is proud to offer a Total product range of hydrotherapy…
Watch Video: Timber Pest Inspections by Resicert Property Inspections WATimber Pest Inspections
Resicert Timber Pest Inspections - Brilliant Inspections, Best Reports, Fast!
Watch Video: SlimWall Designer Fences Installation Video by SlimWall Designer Fences VICSlimWall Designer Fences Installation Video
SlimWall Designer Fences are the popular panel fencing innovation that combines…
