Browse Forums Eco Living Re: yet another rain water setup questions 22Jun 22, 2015 2:59 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: yet another rain water setup questions 23Jun 22, 2015 8:13 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: yet another rain water setup questions 25Jun 22, 2015 10:21 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: yet another rain water setup questions 28Nov 25, 2015 11:49 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: yet another rain water setup questions 30Nov 26, 2015 3:02 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: yet another rain water setup questions 32Feb 01, 2016 1:03 pm B-Man is it normal to have a check valve straight after a ball valve from the tank? - must there be one there? the only reason i can think of is to keep the pump primed If the pump isn't flooded and the tank's water supply can drop below the level of the pump, then a check valve should be fitted. People have also had unexpected high water bills when an automatic switching device has pushed mains water back into the tank and the tank has then overflowed to the stormwater. A check valve should prevent this. Your other questions are plumbing questions, I am not a plumber. Some councils also over-rule some plumbing regulations or add additional mandates, therefore I am reluctant to give an opinion, particularly in the absence of diagrams. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: yet another rain water setup questions 33Feb 26, 2016 2:10 am Hi all from Argentina.. first, sorry for may terrible english.. need advice with my case.. rain water not for consuption use. Very good forum.. And SAVEH2O.. you re a god... hope answers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [img][img]http://s22.postimg.org/6tt3ou7ot/WET.jpg[/img][/img] Re: yet another rain water setup questions 34Feb 26, 2016 8:08 am Hi guillote 1.I recommend you start your own thread 2. only 1 image is showing? was there more? 3. what are you trying to achieve? 4. that seems like an awful lot of roof space for 1 51mm downpipe. 5. I recommend you read the first few posts in this thread as I tried to make it easy for someone to copy it and fill in there own information Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 762 Hi, does anyone have any experience with using Trex rain escape or EPDM rubber to waterproof a deck so you have dry space underneath. Popular in the US and realize that… 0 2638 Yes you are correct, unless there are outside works which form part of the contract such as landscaping or driveways, and importantly, the work delayed is on the critical… 1 2555 |
