Browse Forums Eco Living Re: Solar power and hot water 5Nov 02, 2014 8:46 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Solar power and hot water 6Nov 02, 2014 9:08 pm Custom build Northern NSW viewtopic.php?f=31&t=72217 Re: Solar power and hot water 7Nov 02, 2014 9:22 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Solar power and hot water 9Dec 17, 2014 8:28 pm Custom build Northern NSW viewtopic.php?f=31&t=72217 Re: Solar power and hot water 10Dec 17, 2014 10:33 pm Unless you live in an area that it is blowing a gale all the time (well not quite a gale), then wind turbines are a waste of time and money. To get any real power generation for off grid systems, you will find it far better value to buy more PV panels instead. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20661 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14825 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25072 |
