Browse Forums Home Theatre & Automation Re: Data points expensive 13Oct 19, 2020 6:14 pm Tubrgoats Sorry, maybe a silly q, But why didnt you go for Cat 7 or Cat 8 ethernet? I am doing my build now and deciding if it is worth the upgrade? Mainly, the cost. Is it worth it in a residential setting, absolutely not. Cat6a is as high as you need to go, but even Cat6 will likely be fine. I went for Cat6 because I could get them installed for $95 each, Cat6a was an upgrade to almost $150 each. If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13870 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20682 |
