Browse Forums Home Theatre & Automation Re: TV mounted above gas fireplace yay or nay? 12Oct 15, 2018 11:21 pm Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Re: TV mounted above gas fireplace yay or nay? 13Jul 03, 2019 10:22 am there's nothing wrong with doing it with todays modern gas heaters, however the main consideration is TV height. Optimal TV height is where your eye level while sitting down is exactly 1/3rd of the way up the TV height. For a 75inch TV this means the bottom of the TV needs to be about 80cm off the ground. Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72683 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 14223 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11998 |
