May 26, 2013 12:03 amSign In31 members logged in
Building Forum » Lifestyle » Home Theatre & Automation
Smart Wiring House in Telstra Velocity Estate
New Topic Post Reply  Page 2 of 5
 [ 83 posts ]  Go to page Previous  1, 2, 3, 4, 5 Next
wakeboardandy
 Post subject: Re: Smart Wiring House in Telstra Velocity Estate
PostPosted: Mar 23, 2009 9:17 pm
I don't upload much...
I assume you are running a server, in that case counting uploads wouldn't be great for you..
Djelibeybi
PostPosted: Mar 24, 2009 2:38 pm
Yes, once I'm on fibre, I'll be moving my servers into the house. The servers don't do a huge amount of uploading, but enough so that I'd notice if it were metered. :)
mattym
PostPosted: Apr 09, 2009 3:13 pm
Junior Member
Junior Member
Also building on Bedervale Loop and need the house smart wired.
Thanks for all the helpful information as the Telstra information doesn't really help much.
Matt
kirbstar23
PostPosted: Apr 09, 2009 3:56 pm
Loyal Member
Loyal Member
I have to agree Matt....
Telstra really need to pick up their game as far as information goes. I even rung them.... still struggled to get information like costs from them! Maybe i got a ******* peoson.... but it was like drawing blood from a stone!
Love Kirby
xoxo
Texas Aston Joe became our world on the 20th December 2007
Pregnant again this time Due on Xmas Day..... We must have a thing with December!
Glenn and I are building our dream home.....
http://lifeastherichmonddavisclan.blogspot.com/
wakeboardandy
PostPosted: Apr 09, 2009 4:00 pm
Did you guys call the normal telstra number or the smart community one which is 1800 008 994?
wakeboardandy
PostPosted: Apr 09, 2009 4:40 pm
troubz wrote:
I've found it to be a little lacking on the technical requirements etc....
This document has all the technical requirements you will ever need...
http://www.telstra.com.au/smartcommunit ... y_1108.pdf
faerie
PostPosted: Sep 17, 2009 3:44 pm
Senior Member
Senior Member
Hi guys, I will be building in a Telstra Velocity Estate with M and I have this strange feeling that they will charge us around 5k for a package. Our Electrical appointment is next week.
Just wondering is this something that needs to be installed during the construction stage or can I have my "smart wiring" setup after handover?
Im sure Id be looking at 3 tv points, 4-6 network connections and maybe 2 phone connections. And whatever else is needed such as HDMI or whatever (my partner knows what we need)
any advice would be great! :P
Building: M3tr1c0n - Santorini 26
[30.04.10] Builders on Site
[29.11.10] Handover
[11.12.10] Moved in
[CURRENTLY] Moved in and adding all those extras we couldnt pay our builder to do
http://mnsantorini.blogspot.com
Pugs
PostPosted: Sep 17, 2009 3:49 pm
during construction unless you can get "conduits only" installed I would say you are getting ripped off big time even for that I wouldn't expect anyting over $2K- 2.5K all up...
Kodiak Data Cabling onFaceBook
Consult*, Design and Installation
Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms
Ask for a Quote.
*DIY DATA Cabling Is Ilegal
Zerosignal
PostPosted: Sep 17, 2009 8:12 pm
Sounds expensive to me.
Argus have quoted us around 2k for 9 network/phone points, 2 foxtel HD points, 2 std foxtel points, 4 TV points.
wakeboardandy
PostPosted: Sep 17, 2009 8:24 pm
Foxtel HD, std foxtel and TV points are all the same plugs and are wired to the same splitter. So make sure they aren't charging you any extra to state HD on there.
troubz
PostPosted: Sep 17, 2009 8:42 pm
Junior Member
Junior Member
Hi Everyone,
FTTH or Smart Wiring seems to have caused a lot of confusion, this confusion has also caused many companies to try and cash in with ludicrous pricing, it you want a better deal why not speak to the experts that have done a great many Telstra Velocity installs?
http://www.smartwiringaustralia.com.au
Basic pack including 6 points is only $795 + GST
Monitored Alarms are only $675 + 28.5 monitoring
mel_in_laurimar
PostPosted: Sep 17, 2009 8:55 pm
Junior Member
Junior Member
Nathan from smartwiring aust. is doing our wiring, alarm and theatre room, came in a few thousand dollars cheaper than other quotes and seem quite nice.... also building just around the corner from me....
They are doing a pre wire ( running the cables I assume - not verytechnically minded) before the plaster next week and then come back to fit off at handover.
if you want his details, happy to pass on, always willing to pass on good service
angel
PostPosted: Sep 17, 2009 9:29 pm
Loyal Member
Loyal Member
Hi
I'm also building in Laurimar - Harrisons View, and my builder has installed my velocity wiring....i'm almost at completion stage and have noticed that the 2 double power points for the cabinet has been put in the garage where they were supposed to go according to the plan...but the actual termination point for all the wiring has ended up on the other side of the wall in the broom cupboard (theres a big hole hole in the wall with the wire poking out). I asked the builder about this and he said that the rules have changed and there not allowed to put the box in the garage anymore...does anyone know about this? Seems a bit odd i'd much rather it in the garage and not taking up my broom closet space! And I have heard that the unit should not be in confined spaces...does anyone have any advice? Thanks
troubz
PostPosted: Sep 17, 2009 9:40 pm
Junior Member
Junior Member
Hi Angel,
Telstra install 2 things
1. ONT - which is the box that goes on the side of the house, basically this is where the internal cabling meets the Telstra network
2. a Power supply unit which is basically a big adapter that is installed at the power point where the conduit has been run to, this is almost always in the garage even when it's a starserve system.
In you need any further clarification feel free to call me
Regards
Nathan
0411 145 337
angel
PostPosted: Sep 17, 2009 10:12 pm
Loyal Member
Loyal Member
Hi Nathan
Thank you for your response, I think its the starserve mid size cabinet thats going to end up in my broom closet all the cables that have been run through the house are going to this area. The cabinet was supposed to be on the other side of the wall in the garage where the power points are. When I queried this I was told that there not allow to put the hub in the gararge anymore. The ONT (lead in cable on plan) will be outside on the other side of the house which is ok. Thank you for your number I will probably call you tomorrow as i'm very confused!
troubz
PostPosted: Sep 17, 2009 10:17 pm
Junior Member
Junior Member
Very welcome,
What part of Laurimar are you building in?
I'm building in the Briars
angel
PostPosted: Sep 17, 2009 10:53 pm
Loyal Member
Loyal Member
Hi Nathan
I'm building in Harrisons View...will be moving in, in about 5 weeks (hopefully). What stage are you at? I must say I will be very glad to move there...so looking forward to having my own very fast internet connection, i'm over this sharing one connection were i'm renting!! Its a battle getting air time :-)
I've been renting in Laurimar of Flaxen Hills road for the past 12 months and thoroughly love living in the area!
Helen
faerie
PostPosted: Sep 18, 2009 4:16 pm
Senior Member
Senior Member
troubz wrote:
Hi Everyone,
Thanks for all your replies guys. I still have very little knowledge in this area.
But at that price it doesn't make me freak out as much. However we are building with * and they wont allow us to outsource any other contractors until handover.
So does this mean we have to go with whoever their contractor is and pay there outrageous prices?
[29.11.10] Handover
[11.12.10] Moved in
wakeboardandy
PostPosted: Sep 18, 2009 4:19 pm
nah just sneak them in when no-one is there for the prewire.. ::hyst:: ::hyst::
drafty
PostPosted: Oct 27, 2009 9:09 pm
New Poster
New Poster
I am in Malvern Springs Ellenbrook, We are currently getting quotes for Smart wiring to Velocity netowork not that we have much choice. I am finding a lot of variation between contractors. Intelligent Homes wanted over 3000 for 3 tv a couple of data point. Another in Bibra lake want 2000 for the same thing. I am currently checking with a Electrical company in Greenwood. They seem to have the best price but want to add things like a Signal booster for the TV. Do you actually need a booster? What is a fair price for 3 tv points and 7 data points? Any help would be greatly appreciated.
Users browsing this forum: No registered users and 2 guests
Watch Video: Technology Made Easy With Tuxedo Touch by Honeywell by Raging Technology SATechnology Made Easy With Tuxedo Touch by Honeywell
State-of-the-art home and building automation controller with built in web server,…
Watch Video: Sonos Ipad Application by Digital Life AV QLDSonos Ipad Application
Sonos Ipad application. Very cool!!!!
Watch Video: New Elan "G" Automation by Digital Life AV QLDNew Elan "G" Automation
How would you like to control everything in your home with…
