Browse Forums Home Theatre & Automation 1 Mar 22, 2017 8:05 am Hi all, we just had our speakers installed and the receiver connected and I felt like the rear speaker (actually located above the seating in the bulkhead) weren't loud enough. I went into the settings and turned them up but now I don't know whether I've inadvertently changed the front.... But I've noticed that the front speakers aren't set at the same volume. I'm wondering whether this is because there is a sub on one side and therefore whether some allowance is made for that.... We aren't very cluey with these things! The room is approximately 4x4.2 Any guidance would be appreciated Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Speaker volume 3Mar 22, 2017 11:47 am Whitey22 What position are you holding the test mic at mrsjm ?? Lol test mic?? I'm not very good with this.... Where would I find that? C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Speaker volume 4Mar 22, 2017 12:00 pm Ohh just looks like with ur screenshooted program you have ran a auto tune on the system the test mic would normally be best in your seated listening position and that will adjust the db of each indivivdual speaker does this sound like something that you have done for it ? Re: Speaker volume 5Mar 22, 2017 12:12 pm Whitey22 Ohh just looks like with ur screenshooted program you have ran a auto tune on the system the test mic would normally be best in your seated listening position and that will adjust the db of each indivivdual speaker does this sound like something that you have done for it ? I didn't actually watch the guy set it up unfortunately. I just manually went in when he left and increased the rear. I do remember hearing a really high pitched sound that sounded different to the test tone... Wonder if that was it. Will have a look this afternoon before hubby gets home and chastises me for fiddling with technology lol C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Speaker volume 6Mar 25, 2017 2:26 pm What amp brand and model do you have? I think from the screenshot it looks like a Yamaha? Should look similar to the below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If you play the test tone on the front 2 speakers, do they sound the same? Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: Speaker volume 7Apr 04, 2017 7:42 pm Rest speakers are typically softer unless the movie scene has sound travelling from the front to the rear IE a helicopter flying over your heads. Rear and side speakers compliment the front pair and centre channel. Which speaker cable and brand is best to use in Media room (3.4x3.6m) for Home theatre setup. 0 462 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25550 i did click it, still couldnt make it out rofl. in any case, doesnt look like too extreme a slope, you may be in luck. Just shoot out some emails to volume builders in… 3 18882 |
