Browse Forums Home Theatre & Automation Re: Raspberry Pi/Arduino and other Roll Your Own Home Automa 14Jun 05, 2019 9:19 pm If anybody successfully finished any projects with Raspberry Pi or Arduino - share it here. How to do it and components and little guidance too. I'm interested in it but not a programming or coding expert, but have done small scale like getting Kodi on Pi for HT etc.. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29007 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10417 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20819 |
