Browse Forums Home Theatre & Automation 1 Mar 07, 2016 11:49 am I've been having an issue connecting up my modem router inside the house. The problem first occurred last year where I lost connectivity to all my data sockets inside the house. I used to be able to connect the modem router to the data socket with RJ45 cable and all devices will be connected wireless-ly to the modem router. Ever since that, what i did is unplug one of the jack (blue cable) in the hills box in the garage and connect RJ45 to that socket straight to the modem router and this has work well up, even til now. So, problem is definitely not with Telstra end. BUT, this is not ideal. this is not how it supposed to be set up. Garage tends to get warm and I believe it will affect the life span of this device. I prefer the modem router to be located inside the house and connected to one of data sockets. So issue is, data sockets seems to lose connectivity to the box in the garage. What could be the issue? internal wiring screwed? Do I need electrician to fix this issue? if so, can you recommend anyone that able to service in South West Sydney area? Re: Hills Home Hub Telstra Velocity Data Sockets not working 2Mar 08, 2016 6:30 am Can you add a photo of what you have in the hub? Unless you have a serious vermin problem data cabling won't just stop working; It is more likely to be a problem with the velocity box or your router. Generally I wouldn't expect a garage to get so hot as to seriously impact the life of the router, but your wifi signal may not reach as far if you have the router there. Re: Hills Home Hub Telstra Velocity Data Sockets not working 3May 05, 2016 1:38 am Do you have a switch in the hub that connects all the data points together? Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7550 Okay sorry silly me, my wife has solves the mystery for me. It’s because the labels on the ports are all wrongly positioned by the builder hence it confuses me. 2 1386 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20673 |
