Browse Forums Home Theatre & Automation 1 Jun 29, 2015 10:37 am Hi All, Has anybody here used resilient channel before for soundproofing purposes? Im looking into using this system instead of whisper/quiet clips with normal furring channel. The resilient channel system seems alot easier to install, only have to screw into the oneside and fix into joist. Looking at the resilient channel, it looks very similiar to normal furring channel but missing an edge. So I was wondering, can I make my own resilient channel by using normal furring channel and just tinsnip one side off? Will this work just as well as proper resilient channel? Reason for this extra work is due to proper resilient channels costing twice as much as furring channel but looks very similar. What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2856 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4824 Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39588 |
