Browse Forums Home Theatre & Automation 1 Mar 25, 2015 1:18 pm Can any tell me what the best way to sound proof a home theatre is? I guess at the same time what the most cost effective way to sound proof a home theatre is. I don't want to go completely overboard, I don't mind if a bit of sound is audible outside of the room. Location: Harrington Grove - Laurina Release Builder: Ansa Homes - Georgia 38 Blog: http://thegrewbuild.blogspot.com.au/ Re: Sound Proofing 2Mar 25, 2015 7:09 pm We put sound proofing batts into the walls between a few rooms in the house. Overall they are OK. If i needed more, I'd probably look at a combination of insulation and a gyprock designed for sound suppression. Re: Sound Proofing 3Mar 25, 2015 7:54 pm I can't help with your question but our sales consultant recommend the acoustic batts for our theatre room. I'm still sceptical whether they'll work or not. We are still building so time will tell Re: Sound Proofing 4Mar 25, 2015 8:49 pm There are quite a few other threads on how to soundproof a room on these forums. If you are talking walls then two layers of Soundchek plasterboard on one side then the acoustic batts in between and another two layers on the other side. You can do a lot more of course but it depends on how much cash you want to throw at it. Your builder should be able to give you an idea of price for a few scenarios. Stewie Re: Sound Proofing 5Jun 22, 2015 11:29 am I have tried using weather stripping foam tape around the top and sides of a door frame to create a better air seal that will limit the sound . And on the bottom of the door, i attached a plastic door sweep. i had seen a couple of videos on YouTube and got this going . The bass is much less and i can easily have a great time without worrying too much especially at the nights ! Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 21149 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 17220 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 8027 |
