May 22, 2013 12:05 pmSign In53 members logged in
Building Forum » Lifestyle » Home Theatre & Automation
Sound Reduction Advice in a HT room.
New Topic Post Reply  Page 1 of 1
 [ 5 posts ]
Toohey
 Post subject: Sound Reduction Advice in a HT room.
PostPosted: Jun 13, 2012 10:17 am
Bronze Member
Bronze Member
Hey Everyone.
I have a HT room, around 6m X 4m. The screen, front speakers and Sub are all sitting up against the double brick external wall. On the other side of this wall there is a 1/2m gap then the colorbond fence then id say a 1m gap then the neighbours house. When the sound is quite loud and i stand outside the room between my house and the neightbours i can definately hear quite a bit (not audible but definately noise pollution) and am worried that this may be getting through to the neighbours.
The room which the screen backs onto has 2 large windows that have been covered in with a sheet of standard gyprock that is flush with the wall (just covers up the window to stop the light).
Now am i correct in my thinking that if i remove these 2 gpyrock sheets, build a wooden frame with sound sheets on either side and insulation in the middle to go into the window areas, seal them back up as well as filling the roof cavity above with a bit more sound insulation that the noise going through to the neighbour would be a bit less?
My theory being that its the bass which is mainly getting through and by massing up the window areas this may help a little.
I am not looking to stop the sound altogether as its just impossible on my budget but my aim at least for the short term would be reducing the outside noise enough for me to be able to listen to movies / music a bit louder inside the house without the constant worry that i may be making a racket.
Any comments would be appreciated as id love to get started on this, this weekend.
Home Thread: http://forum.homeone.com.au/viewtopic.php?f=31&t=31062
paulw11
PostPosted: Jun 13, 2012 4:57 pm
Hi
Have a look at the CSR web site. On there you can download a PDF copy of their 'red book' publication - this contains a number of solutions for noise reduction.
You are correct in thinking that sound will pas through the windows - standard plasterboard is effectively transparent for sound, but if you are worried about the bass then you may need to treat the entire wall as low frequencies will be audible even through brick at high volume.
Paul
5 acres in Hartley, NSW
Our House Blog
PHL
 Post subject: Re: Sound Reduction Advice in a HT room.
PostPosted: Jun 14, 2012 11:25 pm
Look at the SoundCheq products as well as acoustic batts (these are denser than insulation batts). Had a wall built with that combination, and you can barely hear from one room to the next even at high volume.
Toohey
PostPosted: Jun 15, 2012 12:51 pm
Bronze Member
Bronze Member
Thanks for the replies, will let you know how we go tomorrow and if it makes much of a difference (fingers crossed)
mattwalker
PostPosted: Jul 13, 2012 11:29 pm
Support Team
Support Team
How did you go with this?
Australia wide Local Call - 1300 85 4441
Click here to look around: http://www.thecableconnection.com.au
 [ 5 posts ]
Users browsing this forum: No registered users and 1 guest
Watch Video: Technology Made Easy With Tuxedo Touch by Honeywell by Raging Technology SATechnology Made Easy With Tuxedo Touch by Honeywell
State-of-the-art home and building automation controller with built in web server,…
Watch Video: Sonos Ipad Application by Digital Life AV QLDSonos Ipad Application
Sonos Ipad application. Very cool!!!!
Watch Video: New Elan "G" Automation by Digital Life AV QLDNew Elan "G" Automation
How would you like to control everything in your home with…
