Jun 19, 2013 9:45 pmSign In85 members logged in
Building Forum » Lifestyle » Home Theatre & Automation
Home Theatre - Speaker placement
New Topic Post Reply  Page 1 of 1
 [ 8 posts ]
Barnseee
 Post subject: Home Theatre - Speaker placement
PostPosted: Feb 29, 2012 5:39 pm
Junior Member
Junior Member
Hi guys,
Ive been doing some research on surround sound in a theatre.
Ive heard that 7.1 suround sound is a waste of time since your players usually dont support this.
The other thing is the speaker positioning. Ive been told that your speakers should be the same height all the way around the room.
I was planning ot have to large stand speakers at the front and 2 smallish speakers on the upper part of my rear walls.
What configuration have you guys gone for? And are you using 5.1?
My Build Thread
viewtopic.php?f=31&t=54256
paulw11
PostPosted: Feb 29, 2012 9:19 pm
Online
Hi
I wouldn't get too worried about precise speaker positions - most AV receivers come with auto set up microphones that will calibrate the timing to account for your speaker positions. Even if you did set them up precisely it would require you to sit in the precisely calibrated location.
I have installed 7.1 as many modern DVDs and all Blu Ray discs include support for the extra surround channels, but 5.1 still sounds pretty good.
Paul
5 acres in Hartley, NSW
Our House Blog
Pugs
 Post subject: Re: Home Theatre - Speaker placement
PostPosted: Feb 29, 2012 10:16 pm
Cable for 7.1 but at the start use 5.1
Kodiak Data Cabling onFaceBook
Consult*, Design and Installation
Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms
Ask for a Quote.
*DIY DATA Cabling Is Ilegal
AussieMark
PostPosted: Feb 29, 2012 10:26 pm
Silver Member
Silver Member
Not sure I agree that 7.1 is a waste of time. I have had both and 7.1 is good, especially if you use Blu Ray. it provides more flexibility in listening. Placement wise, yes most systems can calibrate for odd speaker placement but why not research correct placement for 5.1 or 7.1 as it may not cost any more to get it approx right
ciao
Mark
Barnseee
PostPosted: Feb 29, 2012 10:36 pm
Junior Member
Junior Member
Yeah well that's what I thought. 5.1 will be easier to install on the back walls.
If I cable for 7.1 then I will have wire hangs in the walls.
My concern for the sound was that if your speakers are the same height as your front I'd think it would sound better. I think of it as which directions the sound come from. But note taken for calibration on the setup.
My preference it up on the rear walls cause its neater, not really for sound ambience.
But at the same time I want a sound system that will low you out of the water!
My Build Thread
AussieMark
PostPosted: Feb 29, 2012 11:32 pm
Silver Member
Silver Member
Mount your sides and rears angled down. Some speakers are built that way to allow higher placement. Also for side and rear placements you can build columns and mount quite nicely. Do yourself a favour and check out some of the build threads on http://www.avsforum.com/avs-vb/showthre ... light=show
it will give you some ideas....
cheers
mark
Pugs
PostPosted: Mar 01, 2012 8:51 am
you don't have to have those cables pulled out or have a blank plate covering them, or just mention to your ss to tell the Gprockers not to cut holes for those ones but have plenty of photos/ measuremnts of the locations of the cabling
Ask for a Quote.
paulw11
PostPosted: Mar 02, 2012 9:58 am
Online
Hi
I have done in-ceiling for 7.1 surround and rear before too - works pretty well.
Paul
Our House Blog
 [ 8 posts ]
Users browsing this forum: paulw11 and 2 guests
Watch Video: Technology Made Easy With Tuxedo Touch by Honeywell by Raging Technology SATechnology Made Easy With Tuxedo Touch by Honeywell
State-of-the-art home and building automation controller with built in web server,…
Watch Video: Sonos Ipad Application by Digital Life AV QLDSonos Ipad Application
Sonos Ipad application. Very cool!!!!
Watch Video: New Elan "G" Automation by Digital Life AV QLDNew Elan "G" Automation
How would you like to control everything in your home with…
