May 23, 2013 10:50 pmSign In56 members logged in
Building Forum » Lifestyle » Home Theatre & Automation
HDMI CABLE DIRECTION
New Topic Post Reply  Page 1 of 1
 [ 12 posts ]
Bigmorgs
 Post subject: HDMI CABLE DIRECTION
PostPosted: Jan 30, 2012 10:06 am
Junior Member
Junior Member
Hi,
I recently renovated my house and during the process ran a HDMI cable inside the wall to my patio area TV from my main media area.
Now all the work is done and the walls are up and painted i have gone to setup the TV to discover the HDMI cable has been run the wrong way. At first I did not think this was possible but I have tested it and it's true.
I can't rerun the cable now and need to make this cable work is there any way of doing this with an adaptor or something?
Thanks.
paulw11
 Post subject: Re: HDMI CABLE DIRECTION
PostPosted: Jan 30, 2012 10:29 am
Hi
HDMI cables are just straight-through. They don't have a direction. What problem are you getting? How did you test? If you tested with another cable then perhaps the one in the wall is damaged?
Paul
5 acres in Hartley, NSW
Our House Blog
paulw11
PostPosted: Jan 30, 2012 10:36 am
Hi
I did find this: http://www.avsforum.com/avs-vb/showthread.php?t=1070303 Does your cable have an amplifier in it? That is a circumstance where it could be directional.
Paul
Our House Blog
Pugs
PostPosted: Jan 30, 2012 12:34 pm
some are dirstional and need to be run the right way... you will need to re run the cable... or install a standard cable
Kodiak Data Cabling onFaceBook
Consult*, Design and Installation
Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms
Ask for a Quote.
*DIY DATA Cabling Is Ilegal
Bigmorgs
PostPosted: Jan 30, 2012 12:52 pm
Junior Member
Junior Member
paulw11 wrote:
Hi
Paul
I tested it by running a signal the other way.
I also have one of these cables left over at tested it also and it too only works one way
No amp as far as I can see. It just looks like a normal HDMI cable.
paulw11
PostPosted: Jan 30, 2012 3:12 pm
Hi
Are there any markings on the cable that indicate direction? Do you have any information on the cable (brand etc)?
How long is the cable? It sounds like it might be an 'active' cable with some sort of amplification built-in. A standard HDMI cable just connects the pins at one end to the pins at the other and therefore is independent of direction.
Paul
Our House Blog
cray-
PostPosted: Jan 30, 2012 5:17 pm
Junior Member
Junior Member
In theory couldn't you cut the ends off, swap them over and reconnect? I'm not sure how fine the individual strands are inside an HDMI cable, might be an exercise in frustration, might leave you with a very expensive draw wire.
Pugs
PostPosted: Jan 30, 2012 5:53 pm
not in theory or in practice...
Ask for a Quote.
cray-
PostPosted: Jan 30, 2012 6:55 pm
Junior Member
Junior Member
OK I'll pay the "practice" half, but why not in theory? I'm assuming that whatever electronics make this an "active" HDMI cable is housed in or near the plugs, the cable itself is just cable, no?
fairy blue
PostPosted: Jan 30, 2012 7:14 pm
This is so far out of my comfort zone with advice i really shouldn't bother. Is it possible to attach rope to the hdmi cable and then pull it out of the wall leaving the rope in, reverse the cable, tie it back to the rope and then pull it back through? Please feel free laugh if my advice is inappropriate. :lol: :lol:
Meagan
2009 Build thread: viewtopic.php?f=31&t=15440
Landscaping thread: viewtopic.php?f=19&t=37198
paulw11
PostPosted: Jan 30, 2012 7:54 pm
Yes, that is the best hope - use the existing cable as a draw wire.
Worst case if you are just dealing with plasterboard you may need to cut some holes, patch and repaint.
Paul
Our House Blog
mattwalker
PostPosted: Feb 07, 2012 10:39 pm
Support Team
Support Team
This is the best option in my opinion.
There is no great way to do this.
Unfortunately some retailers are selling directional HDMI in longer lengths where there is really no need.
We offer a 15 metre HDMI cable with no direction on it and it works just fine.
Failing this you may be able to run a pair of cat 6 cables and use these as a transport for your HDMI if there is not enough space to get another HDMI cable through.
Another option is a wireless HDMI sender like this if all else fails:
http://www.thecableconnection.com.au/TC ... where.html
Australia wide Local Call - 1300 85 4441
Click here to look around: http://www.thecableconnection.com.au
 [ 12 posts ]
Users browsing this forum: No registered users and 2 guests
Watch Video: Technology Made Easy With Tuxedo Touch by Honeywell by Raging Technology SATechnology Made Easy With Tuxedo Touch by Honeywell
State-of-the-art home and building automation controller with built in web server,…
Watch Video: Sonos Ipad Application by Digital Life AV QLDSonos Ipad Application
Sonos Ipad application. Very cool!!!!
Watch Video: New Elan "G" Automation by Digital Life AV QLDNew Elan "G" Automation
How would you like to control everything in your home with…
